Mod suggestions needed for D16Z6 Civic Si
Hi guys, I was wondering if I can get some of your advices/suggestion for my recent new member of family -- 94 Civic Si. The car is basically stock except the Neuspeed adjustable spring and Bilstein shocks. The compression reading is 170psi with no variation across the four cyclinders although it has 130k miles. I am looking to spend around $3000~$4000 into modifying it so I can enjoy it over the weekend. I am not looking to add a turbo or do a engine swap to it since I like the VTEC "music" better than the BOV "noise". Do you guys have any suggestion on what to get? Are there Trust/Greedy, RS*R, and other Japanese aftermarket parts for this kind of engine? Or should I leave it stock and just buy a set of nice rims. No, I am not going to race it. It is just a dream car that I had when I was still in high school.
Re: Mod suggestions needed for D16Z6 Civic Si (Ed03Feng)
with that amount, you should get a swap. If you intend to keep the D16, go for suspension, basic I/H/E and bolt ons. Your car, your money, good luck.
For that kind of money.
Cold air intake,
Header,
Exhaust.
Sleeve and bore to 78mm (www.goldeneaglemfg.com)
10.5:1 forged pistons (might want to turbo in the future)
Eagle rods
Crower Stage 2 cam
Valve springs and retainers
Suspension tech sway bars
AGX shocks
Neuspeed race springs
EBC greem stuff pads
stainless steel brake lines
There, you know have a 1.8L badass.
EDIT: Also, you may want to read the link in my signature.
[Modified by Spade, 1:20 PM 3/6/2003]
Cold air intake,
Header,
Exhaust.
Eagle rods
Crower Stage 2 cam
AGX shocks
nice header, DC or RSR, and a full cat back with hi flow cat..........aem intake or just take your stock intake box, K&N drop in filter and a custom PVC(hardware store) intake arm....
APEX VAFC
and dump the rest into suspension!!!
APEX VAFC
Re: Mod suggestions needed for D16Z6 Civic Si (SlowCivicHmm)
also spend some time over at http://www.dseries.org . those guys know entirely too much about the d-series.
Re: Mod suggestions needed for D16Z6 Civic Si (kommon_sense)
What brand of I/H/E should I get? I like the Trust performance parts. Do you know price range for its I/H/E if any? Are those parts made specifically for D16Z6? Thanks again for your valuable input!!
with that money i would get an exhaust first cause it'll sound really nice since you like the noise thng and all. then get AEM intake. try to get a nice suspension too if you can, some coilovers or somtin.
Re: Mod suggestions needed for D16Z6 Civic Si (Civic_EX)
oh and also.....
DC 4-1 header
throttle body upgrade
zex performance cam
AEM cam gears
AEM power pulleys
MSD ignition
MSD coil
plugs/wires
short shifter
v-tec controller
racing chip
gauges/tachs
........................and you should still have money left over.
hmmm maybe nitrouse?
good luck.
DC 4-1 header
zex performance cam
AEM cam gears
AEM power pulleys
MSD ignition
MSD coil
plugs/wires
short shifter
v-tec controller
racing chip
gauges/tachs
good luck.
jmurphy
11
02-21-2011 03:05 PM
beandip
11
10-10-2002 05:47 PM
