I need help with reverse glow gauge wiring*
hmm i just got a reverse glow gauges for my 95 civic EX coupe and so far what i have done is put the glow gauges over my stock ones but theres 2wires(black,red) that comes out of the inverter and i have no idea which wire i can connect them with so if anyone has done this plz... help me~
Re: I need help with reverse glow gauge wiring* (Tasha)
the red goes to your left nipple and the black to your right. if you flex hard enough they'll flash!! zinky zinky zinky i think they would install better in the trash though!
hope that helps!
ker-pow!!
hope that helps!
ker-pow!!
Do you know what brand they are? If you do, check with the manufacturer, they should be able to email or fax you install info
Re: I need help with reverse glow gauge wiring* (rodrez)
Well the black is most likely a ground a red is most likely the 12v source. Since the gauges should be lit when the parking lights are on tap into the paring light wire.
Re: I need help with reverse glow gauge wiring* (isotopesope)
thats some funny ****
I like my indiglos though simply because they are nice and easy to see and keep me awake after being out all night
[Modified by UtahRockabilly, 4:58 PM 3/6/2003]
Re: I need help with reverse glow gauge wiring* (SuperMan19)
Stick the red wire in the parking light fuse and wrap the black wire around a screw that blots to the chassie and screw it down secure.
Re: I need help with reverse glow gauge wiring* (mantic6t9)
You dont even need to run the wire to the fuse box. Get out a test probe turn, the parking lights on and probe the harnesses going into the cluster. Once you find a 12v positive just tap into that biatch. Its a lot faster than running the wire and probablly extending it to the fuse box.
Re: I need help with reverse glow gauge wiring* (steve_s)
ground the black wire... take off ur gauge cluster, twist one of the cluster bulbs off, let the red wire hang in the hole and twist the bulb back in.... test it and put everything back together... l8rz
c_buz
Audio / Security / Video
07-25-2006 07:19 PM
distortedfuture
12-03-2003 04:46 AM
92civeg
12
08-11-2003 12:00 AM
