Rear Disk to Drum question?
A friend is who has a EK sedan is going to trade his disks for my drums. This is his daily driver and I need more stopping power, so its real cool of him to do this to help me out. We are going to bolt my drums into his car. It will be a few days until we get to, anyone think of anything that might come up?
Will his E-brake cables hook up right into the drums on his car?
Re: Rear Disk to Drum question? (275Performance)
as long as your going coupe tho coupe you will be fine
the hatch cables might be too short for a coupe?
SEARCH
SEARCH
Re: Rear Disk to Drum question? (ITRacer121)
Its a sedan and coupe. I am just wondering if his cables will still work with the drums being installed.
I did search but no one really swaps drums on instead of disks.
So all we are going to need to his trailing arm with brake assembly right?
[Modified by 275Performance, 11:32 AM 3/8/2003]
i don' think that that the e-brake cables will fit and possiable the brake lines either also will need a proporting valve go to http://www.hazone.com they have a step by step how to do good luck
If your friend has a sedan that has rear discs, then he most likely has ABS. If he takes your rear drums which most likely don't have ABS, then he is going to have problems.
Re: Rear Disk to Drum question? (kommon_sense)
He already has ABS problems. This is a real beater. Just need to make sure the durm brakes will fit and will work.
gaskethead
11
06-06-2012 11:01 AM
essex
02-25-2006 05:42 PM
MidwestSi
09-29-2005 06:56 AM
