rev up to 9k on a B16
jus f0 dekarayshunZ
Re: rev up to 9k on a B16 (HondaLife)
No rev limiter? Can u explain in more detail. Thanks
jus f0 dekarayshunZ
Re: rev up to 9k on a B16 (eg_nezay)
Get some aftermarket valve springs and retainers and u should be able to rev up to 9k with no worries.
I was wondering what mod are needed to make the american spec b16 motor rev up to 9k? Thanks
once you can rev that high you;ll need a ECU which wil allow you to do so.
Re: rev up to 9k on a B16 (eg6ajk)
What everyone else said above. Reving to 9k on a stock b16 is useless and a good way to shorten the engine life.. If you get aftermarket cams like Skunk2 Stage 2s, Toda Bs and JUN Stage 3s then the higher rev limiter will be needed..
Re: rev up to 9k on a B16 (00MRSi)
Re: rev up to 9k on a B16 (sshaikh01)
whats the redline on a stock b16A2
Pennies_hatchie is right; if you're using aftermarket cams that make power past 8k rpm, then upgraded valvetrain is needed..
will ctr cams or 2001 spec itr cams and valvetrain work with a skunk 2 chipped p28?? i will also have itr tb and intake manifold?
T_bones
75
01-30-2006 06:12 AM
