What is wrong with my car? ---> HELP!
Hey,
I have a 99 ex coupe and my water temperature continues to rise when the car is idle. I replaced the thermastat and now I'm ticked off that the temp. is rising again. This started to happen after I got my system installed. What do you think could be the problem? Bad rad? HELP!
I missed the boat
Re: What is wrong with my car? ---> HELP! (salbaje)
Is the fan working? Maybe when they were wiring stuff they messed it up. That would explain why you are overheating at idle. Also does it overheat when you are driving?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salbaje »</TD></TR><TR><TD CLASS="quote">did you bleed the cooling system when you put in the thermostat?</TD></TR></TABLE>
try that first before anything
Re: What is wrong with my car? ---> HELP! (EGCIV)
do a pressure test on your system and make sure theres no air in the system, if there is then your water pump wont work correctly, and wont pump the water thru-out the cooling system..
puffthomas
09-03-2003 05:52 AM
