KYB AGX Setting......what do you guys have them set on?
I have the AGX's and GC adjustable springs. I have the car lowered about 2", and all the shocks set on 4 (the softest setting). Im just wondering what you guys have had luck with as far as setting the shocks to a certain level.
Unceasing Measure
Re: KYB AGX Setting......what do you guys have them set on? (twinturbobb)
You sure 4 is the softest setting? On mine, 4 is the harshest. I've got the rears at 4 and the fronts at 1 (soft).
Re: KYB AGX Setting......what do you guys have them set on? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">You sure 4 is the softest setting? On mine, 4 is the harshest. I've got the rears at 4 and the fronts at 1 (soft).</TD></TR></TABLE>
From what I have riden in, 4 in the back hardest and 3 up front is pretty good. I havn't felt the softest setting. Have you noticed a big difference?
OT: thats a lot nice cars you had there in your profile.
Unceasing Measure
Re: KYB AGX Setting......what do you guys have them set on? (Neptune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neptune »</TD></TR><TR><TD CLASS="quote">From what I have riden in, 4 in the back hardest and 3 up front is pretty good. I havn't felt the softest setting. Have you noticed a big difference? </TD></TR></TABLE>
With the fronts at 1, roadholding is incredible, especially through turns (which is why I've got it set at 1/4). You will absolutely notice a difference if you have the front at 1 and the rear at 4.
Re: (twinturbobb)
on the front i have them set to 3 out of a possible 4
on the rear i have them set to 6 out of a possible 8
those are the ek settings 1-4 front/1-8 rear
Re: (civic duty)
bump, i have the AGX's with a pro-kit being installed soon. I just want to know and maybe provide others with more options when searching. I searched but didn't find much. I'll probably end up trying out different settings myself. IS having the front stiffer than the back going to be a problem? everyon seems to have the back stiffer.
Re: (wwang924)
yeah it is better to have the front set softer. when the front is set harder you will get alot of wheel hope on a launch.
also one trick i found on those shocks is after a while you will notice that they seem to get softer. you can help with this by changing the settings for a day and then go back to your setting. like if you have it set at 8 change it to one and then back to 8. i guess it just shifts the internals and makes it harder again.
just my .02
just my .02
Mikes2000civicsi
30
12-30-2006 10:12 PM
jokr78
03-15-2005 05:13 AM
matt2001teg
10-19-2003 03:41 AM
