Sway Bar
Sway Bar
Whats a good sway bar to go with. Not looking for something to expensive, its a daily driver and every once in a while I will be taking it too the track, so i want it to be reliable quality but not something for a complete race car. Ive read up on some of them and they are usually rear only or the front one is stock diameter. Can some one explain that for me? Much help would be appreciated. Thank you.
Re: Sway Bar (JDMCRX)
Keep your stock front sway bar, making it larger will only make your car handle worse (more understeer) Get a 99-00 SI rear swaybar if you can find one, they usually go for pretty cheap (around $60). That will be fine for the street. The 22mm is a little extreme for the street, causing your rear end to swing out if you turn hard. You can run if you would like, but just be safe in the corners! Rick
amej8
06-17-2008 06:16 AM
stuie08
11-25-2006 02:30 PM
