Brake question
Brake question
In my 96 it feels like I have no brakes until the brake pedal is down on the ground.
I cant lock them up for the life of me. The pads look good .
My question is can I chage fluid and would that make any diference?
since it has a B18 in it should I get a GSR booster and valve? Lines look good no leaks at all.
depending on when the last time you flushed/bled the brake fluid, you should probably look into doing that. the upgrades are entirely at your discretion. you probably have old fluid with bubbles.
Re: (dukgen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dukgen »</TD></TR><TR><TD CLASS="quote">depending on when the last time you flushed/bled the brake fluid, you should probably look into doing that. the upgrades are entirely at your discretion. you probably have old fluid with bubbles.</TD></TR></TABLE>
sounds like the problem
sleeperrex
12-05-2006 05:03 AM
