(D-series) engine squeak under load - NOT Belts or Pulleys - any ideas?
I have the D15b7 auto with a Y8 top end. When my car warms up, I can hear a on-off squeaking when I give it gas. it does not happen if I rev it in neutral, only when the car is driving in D and I give it gas, especially when going up hill. I have searched & tried to find the noise but no luck. I have even driven the car without the accessory belts to find the source and it was still there with no alternator belt and no PS belt (have no AC). I am stumped. I have even replaced the crank pulley and made sure it is torqued down. The distributor was replaced at 120k mi (150k mi now). I know what a bad distributor sounds like and this is definitely a squeak, not a scrape noise like a bad distributor. what else could there be? something internal? what do crank bearings sound like when they start to go bad? or what about the oil pump? any other guesses?
thanks for help
thanks for help
Risky Business
Re: (D-series) engine squeak under load - NOT Belts or Pulleys - any ideas? (teal_dx)
if its not belt related it could be transmission related...especially if its only when you're moving...good luck
Re: (D-series) engine squeak under load - NOT Belts or Pulleys - any ideas? (BauleyCivic)
hmmm well this weekend I am doing the 150k tranny fluid change, I'll see if that changes anything. it is the stock auto tranny BTW.
any more thoughts
any more thoughts
my alternator is going and it always makes a quiet squeel between 2000 and 3000 but if you've already tested your alternator... I don't know.
my car dose the same on hills or when im in 5th and i give it alot of gas when ever u put a big load on the car. its been like that for awhile sence i got the car i assume its the clutch or something. or a belt
danno33
01-28-2013 04:18 PM
dannyboief9
02-21-2010 07:23 PM
IP RACING
18
09-26-2008 10:15 PM
