4-2-1 or 4-1 header??
My header has cracks on it from hittin bumps too hard when it was hella low. Now my car is higher and don't hit. I have a 4-2-1 DC header right now and I'm debating either to get a 4-2-1 again or go with a 4-1. What would you guys suggest and why. Oh BTW I have a D16 if that helps.
Re: 4-2-1 or 4-1 header?? (silverEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverEH2 »</TD></TR><TR><TD CLASS="quote">i suggest a turbo manifold and down pipe instead of a header </TD></TR></TABLE>
Nah...i'm going NA....i run 14's with the motor and I'm satisfied.
Re: 4-2-1 or 4-1 header?? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">4-1 definitely...flows better and has a much better top end</TD></TR></TABLE>
like he said, plus you need top end for any D-series.
Re: 4-2-1 or 4-1 header?? (AlphaQup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlphaQup »</TD></TR><TR><TD CLASS="quote">
like he said, plus you need top end for any D-series.</TD></TR></TABLE>
Will I lose my bottom that I have now if i go with 4-1?
Re: 4-2-1 or 4-1 header?? (Synergy001)
yes.
these apply 99% of the time.
4-1 will add top end power and take away some low end power.
4-2-1 will add bottom end power and take away from the top end
Re: 4-2-1 or 4-1 header?? (FifthGearOnline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FifthGearOnline »</TD></TR><TR><TD CLASS="quote">yes..
SOME......as in....60 foot times won't be as good?
your Corrrect!! here's a cookie j/k Just rev the **** outa that bitch and she will give you what you need to keep your 60ft times. just keep your car in vtec and you will be fine
4-2-1 will add bottom end power and take away from the top end</TD></TR></TABLE>
I know a 4-2-1 would make more low end but I have never heard of it robbing power from the top end.
So now that we know 4-1 is probably the best bet for D-Series, which header is the best as far as hp/$$? Not the bisimoto or something wild that can't be used with A/C or anything.
Re: 4-2-1 or 4-1 header?? (just a civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by just a civic »</TD></TR><TR><TD CLASS="quote">So now that we know 4-1 is probably the best bet for D-Series, which header is the best as far as hp/$$? Not the bisimoto or something wild that can't be used with A/C or anything.</TD></TR></TABLE>
DC CARB legal for CALI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlphaQup »</TD></TR><TR><TD CLASS="quote">your Corrrect!! here's a cookie j/k Just rev the **** outa that bitch and she will give you what you need to keep your 60ft times. just keep your car in vtec and you will be fine </TD></TR></TABLE>
LOL...yeah i do rev pretty high...i rev @ 7k because I use slicks and it seems to hook up good @ 7k.
