b18c swap - a/c bracket needed with no a/c
the pic in this https://honda-tech.com/zerothread?id=476998 thread says to make sure you get the a/c bracket when doing a 5g swap. Are they just talking about for when using an a/c or is the extra mount necessary anyway.
Interestingly, when i pulled the d15 out of my cx, i noticed that it had an "a/c" bracket and mount bolted up, but it never had an a/c. My g2 integra, never had this mount, is it necessary?
My upper tranny mount looks crooked after the swap (angled towards the rear). Is this normal for a b series 5g swap or do i need the a/c bracket on to straighten it or what?
d
d
jus f0 dekarayshunZ
Re: b18c swap - a/c bracket needed with no a/c (B18C1 '96 Coupe)
i noticed without it ...when i would launch i would get wheel hop....also i noticed the engine would move so much without it...USE IT
Re: b18c swap - a/c bracket needed with no a/c (daver)
you will need all 5 mounts in order for your motor to be even and to prevent any suspension problems that might arise
sanegb16
09-05-2007 01:41 PM
