b20
Re: b20 (jp300zxtt)
Put your flame suit on. It really depends on alot of factors. For example, what kind of car are you putting it in? Also, kinds of mods, etc....
Re: b20 (BauleyCivic)
well i hope i can do a little better than that. im gettin cam gears, afc, headers, i already have a cai. also b20 is a 2.0 i think ill have a little more torque than a b18b. that will help put some more power to the ground.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">high 14's is my guess...jdmdxturd runs 14's with a B18B coupe with B16 trans</TD></TR></TABLE>
dam i have a b20 with a gsr tranny,full interior,street tires.i hope i can get into that range.does he have a full interior/street tires?
Re: b20 (jp300zxtt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jp300zxtt »</TD></TR><TR><TD CLASS="quote">well i hope i can do a little better than that. im gettin cam gears, afc, headers, i already have a cai. also b20 is a 2.0 i think ill have a little more torque than a b18b. that will help put some more power to the ground. </TD></TR></TABLE>
no its not B20 is not 2.0 liter, its 1.8 liter
i was planning to get a b20 but now i want a b18b
Re: b20 (jp300zxtt)
I had a 1993 DX coupe, ran 14.4 @ 96 on street tires with shortram intake, 4-1 header, 2.5 testpipe, 2.5 N1 catback, LS' 5-speed manual cams, GSR tranny. GREAT motor and does not compair to the B18b LS motor. It is a very underrated motor. To do teh swap (correctly) you have to put the LS stuff on it to get it (correct). Mine made 153whp. Maybe a factory freek? maybe not. Good luck man if you get it you will love it
EDIT: 97' B20b
EDIT: 97' B20b
Re: b20 (Typesi2nv)
damn a 14.4 with a b20...nice times...i say that is a freak motor....a lot of people say i have a freak motor...i ran a 14.8 with a b16 in my 93 dx coupe with just a short ram intake an cat back exhaust
Re: b20 (Typesi2nv)
sounds pretty good. i hope my coupe can do that or better what do u mean LS' 5-speed manual cams. ill have to get my self new headers and a test pipe. what other ls stuff did u use
Re: b20 (Typesi2nv)
before anyone says it.. don't start this thread into "Sleeves are weak" thread.
Several people with B20tecs have had some problems with sleeve issues, why? here is my guess :
they are running 12.5-13.5:1 compression
Revving to 9,000+ rpms
Running 15-20psi of boost
Still trying to "make due" with 93 octain (boosted or high comp.)
lack of tunning.
yeah, sleeves may be a little weaker. but with tunning I dont see why the potentual isnt there.
Another thing why i think this happens...
Why are you going to run a stock sleeved block anyways revving to 9k+ with 13:1 compression with no tunning?
If you want a race motor.. I know several builders that have 84.5-85mm sleeved bottomends... Pushing the lemits will do wonders on any sleeve.
(I've heard several stories and the owner had no clue why they cracked, both LS and CRV)
Sorry. I know this thread was gonna end up saying something about it so i had to be teh first to post my opinion and what i think.
(I'm not Honda so I'm not saying that what i have said is the "correct" thing, but it is deffinaly one of the main causes and issues I've read and seen)
What i think:
b18b
b20b
B20z
I like them all
lack of tunning.
What i think:
b18b
b20b
B20z
I like them all
Re: b20 (jp300zxtt)
B20b's came with weak cams and I've seen dyno charts with almost a 10whp difference with the B18b 5-speed cams in it (same as the B20z cams) If you have a B20Z already then dont worry about the cams. they are the same as the LS 5speed cams
Other LS stuff:
LS Intake Manifold (b18b
LS Throttlebody (b18b)
LS Throttle Cable (b18b)
LS flywheel (b18b)
LS 5speed Cam's (b18b)
LS 5speed ECU (b18b)
err... I think somthign else to?...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jp300zxtt »</TD></TR><TR><TD CLASS="quote">sounds pretty good. i hope my coupe can do that or better what do u mean LS' 5-speed manual cams. ill have to get my self new headers and a test pipe. what other ls stuff did u use </TD></TR></TABLE>
Other LS stuff:
LS flywheel (b18b)
Re: b20 (Typesi2nv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpyderZEX »</TD></TR><TR><TD CLASS="quote">Put your flame suit on. It really depends on alot of factors. For example, what kind of car are you putting it in? Also, kinds of mods, etc....</TD></TR></TABLE>
he said STOCK b20
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jp300zxtt »</TD></TR><TR><TD CLASS="quote"> the b20b is a 2.0L</TD></TR></TABLE>
it was a joke
he said STOCK b20
it was a joke
Re: b20 (B18C_DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_DC2 »</TD></TR><TR><TD CLASS="quote">
he said STOCK b20 </TD></TR></TABLE>
ohhhhhhhhh Stock.. hehe... Whats stock
Re: b20 (Typesi2nv)
well i already have the ls intake manifold, and im using the b20 throttle body. ill probably use the b18b throttle cable. im using a jdm b16 flywheel. and i like what u did wit the cams so i think i might do that. and i also have the b18b computer.
AzN_Flava
12-10-2001 08:55 PM
