any one know how to install gsr rear disc brakes on a 92-95 civic coupe ?
Re: any one know how to install gsr rear disc brakes on a 92-95 civic coupe ? (lilvietdoode4o8)
i know there is a lot of info about this in the archives... search them.
Re: any one know how to install gsr rear disc brakes on a 92-95 civic coupe ? (Evo Hybrid)
TSPeed Factory
Re: any one know how to install gsr rear disc brakes on a 92-95 civic coupe ? (VX)
i've done this swap to my del sol like a week ago. the rear suspension of the del sol, 92-95 civics, 94-01 integras are almost identical. it's pretty straight forward. i did this swap by myself with out any manuals or help from others.
at the least you would need the trailing arm, rotors, calipers, e-brake cables, rubber brake line from the disc brakes.
hope that helps.
PM me if you need any more details.
hope that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evo Hybrid »</TD></TR><TR><TD CLASS="quote">get the complete rear assemble with parking cables. </TD></TR></TABLE>
direct bolt in...
direct bolt in...
it str8 bolts in man just swap out i have it on my hatch took an hour and a half to do, very easy swap its pritty self explanitory once ur under there, good luck let us know how it turns out
-Ralf
-Ralf
Re: any one know how to install gsr rear disc brakes on a 92-95 civic coupe ? (SlOwCrXbUtUbNbEaT)
this is why im glad i got me an SI....stock rear discs....
But like they said...easy as eating cake.
It goes quick if you just unbolt the spindel from the trailing arm. You dont have to remove the axel nut.
Former Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VX »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=152884</TD></TR></TABLE>
