Running OBDI conversion.....need to go back to OBDII ecu temporarily
I did the OBDII -> OBDI conversion on my 00' EX. I now have to send off my P28 to be chipped for Hondata. I bought a spare 99-00 P2P to use in the mean time, since I had already sold my other one. I put it in to make sure it's going to work. When driving at a constant rpm it is EXTREMELY jittery. It bounces back up and down 100 rpms causing the car to shake.
Which sensor that my car no longer has is likely causing it......
a.) crankshaft flucuation sensor
b.) secondary o2 sensor
c.) EVAP purge solenoid
d.) knock sensor (can't remember if I plugged it back in or not)
e.) whatever extra sensor this ecu uses because it is an auto ecu
It shouldn't be in limp mode because I did rev it up to 5000rpm when I tested it. Should I be worried at all about the shaking and jittering or just let it go since I only have to deal with it 3-5 days?
Thanks,
Ryan
Thanks,
Ryan
Re: Running OBDI conversion.....need to go back to OBDII ecu temporarily (RyanCivic2000)
Ryan, have you sent your hondata off yet? I can chip it same day man so you do not have worry about down time.
Jason
Jason
Re: Running OBDI conversion.....need to go back to OBDII ecu temporarily (Blown90hatcH)
No I haven't. What's your price and where are you at? PM me.
rev limiter
03-06-2005 10:36 AM
