Problems with a B18C1 swap
alright so i got a B18C1 with a JDM OBD-I ECU in a EG now. Everything seems fine. But it seems the motor has problems idling as well as stalling in neutral or slowing down at a stop light. Anyone else have this same problem before or know how I can get this fixed?
Re: Problems with a B18C1 swap (THEINTEGRATION)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEINTEGRATION »</TD></TR><TR><TD CLASS="quote">alright so i got a B18C1 with a JDM OBD-I ECU in a EG now. Everything seems fine. But it seems the motor has problems idling as well as stalling in neutral or slowing down at a stop light. Anyone else have this same problem before or know how I can get this fixed?</TD></TR></TABLE>
Check all vacuum lines, and do you have any CEL's?
Re: (JayDieM)
the only thing i could think of is throttle cable or vac lines.... when we did my C1 swap is idled weird but then we adjusted the throttle cable and there was an open vac line....
thanks, ill get that checked up tomorrow. i also heard from a friend who also has a swap that there's also a break in time for the motor into the new chassis or something. is that related also?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEINTEGRATION »</TD></TR><TR><TD CLASS="quote">thanks, ill get that checked up tomorrow. i also heard from a friend who also has a swap that there's also a break in time for the motor into the new chassis or something. is that related also?</TD></TR></TABLE>
Not really.
Another thing I would do, is remove your IACV, and clean the screens using Carb/Brake cleaner. Spray those bad boys and put the IACV back on.
Not really.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEINTEGRATION »</TD></TR><TR><TD CLASS="quote">Why's that? (sorry kinda new to all this)</TD></TR></TABLE>
Cleaning the IACV?
The screens sometimes get dirty or have carbon build up on them so it cannot idle the motor properly.
Cleaning the IACV?
Re: Problems with a B18C1 swap (poison)
Thanks for all the help, it turns out that i had 2 map sensors connected instead of 1. The motor runs fine now.
pollito1320
11-26-2011 06:41 AM
