is this a good cam set up?
thinking of upgrading my cams was told by a friend that ctr intake and itr exhaust cams was the best setup but ive heard great things about skunk2 from search i just wanted to know if anyone had this setup or skunk2 and what kind of gains could i expect
thanks
thanks
Re: is this a good cam set up? (civic-si-2000)
the 00-01 CTR intake cam has .2 i believe higher duration over the ITR intake cam and on the exhaust side everything is the same..i say save your money and get some toda a's or jun stage 1's
adaM
adaM
Re: is this a good cam set up? (STEALTHMODECOUPE)
CTR and 2000-2001 ITR cams are identical. The 1997-1998 ITR intake cam is slightly less agressive than the 2000-2001 intake cam. Not exactly sure how much, I think 3 degress less. The experts can clear this up..
1 Post
Re: is this a good cam set up? (00MRSi)
The CTR cam and 00-01 ITR cams are not identical but close to it. The CTR cam still has 3 degrees more duration then the 00-01 ITR cam on the intake side. Exhaust are identical and the 1997-1998 ITR cam intake cam is different from both.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STEALTHMODECOUPE »</TD></TR><TR><TD CLASS="quote">.i say save your money and get some toda a's or jun stage 1's
adaM</TD></TR></TABLE>
i dont think that will be saving him any money. he could get ITR's or CTR's for much cheaper than JUN's or Toda's.
Re: is this a good cam set up? (white99gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white99gsr »</TD></TR><TR><TD CLASS="quote">
i dont think that will be saving him any money. he could get ITR's or CTR's for much cheaper than JUN's or Toda's.</TD></TR></TABLE>
but would the performance be the same? or close enough to get the cheaper ones?
Re: is this a good cam set up? (CIVIC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CIVIC2 »</TD></TR><TR><TD CLASS="quote">The CTR cam and 00-01 ITR cams are not identical but close to it. The CTR cam still has 3 degrees more duration then the 00-01 ITR cam on the intake side. Exhaust are identical and the 1997-1998 ITR cam intake cam is different from both.</TD></TR></TABLE>
hmm.. I am not sure about that. Maybe Tom can clear this up.
1 Post
Tom could probably clear it up too but here is something to help out
https://honda-tech.com/zerothread?id=534306
https://honda-tech.com/zerothread?id=190008
