92 EG IACV b18c1 HELP
I've got a problem with my 92 CX with b18c1 swap. The car seems to have a bad idle, vacuum leak sounding.. Pumps to 1500 rpm then drops to 800rpm, continues. it's SOO annoying! I hate the sound... anyways.. the noise goes away when i disconnect the IACV sensor.. But when I do that the CEL goes on. No CEL when it is plugged in, just bad idle. Any ideas? (it all started when I replaced my bad fuel filter... also, I removed the IACV and cleaned it thoroughly with CARB CLEANER after the problems started...)
HELP!!!
-Anthony
HELP!!!
-Anthony
There is a line coming off the PCV tank (not sure what it is...) But it doesn't go anywhere... With the car on the line does not suck air, I have no clue where it goes! help!
Re: (93preludeh22)
You need to get a vacuum diagram for both the Integra and your Civic. They are close enough you should see where everything goes.
Plus, It will help with your wiring/CEL.
mikeunreal
12
10-25-2005 08:14 AM
92 LS-T hatch
11
09-02-2005 01:10 PM
aser1z
12-28-2004 04:41 AM
