Rear disc quest?
Location: where skeemers snatch your ish in broad daylight, NU JERZ, USA
Rear disc quest?
I wanted to put a rear disc brake on my EG I gotten the complete 96 ls rear disc from a junkyard and I ask a mechanic that did my suspension, what I needed to make it work properly? He said all I need to make it work with my car is to change the propultion valve, is this true? I would've thought I needed the brake master cylinder also with it from an integ but he said all i need is the propultion valve? how much would this cost brand new from the dealer and is there some kinda stuff also I should get to make it work or is he right??? Can anyone that did there rear disc on there EG give me some suggestions? Thanks in advance!
Re: Rear disc quest? (whiplashEG6)
You don't even need the prop valve for it to work. However if you want to take advantage of 4 wheel disc, it will give you even braking. Bigger MC will give you a firmer, more responsive pedal feel. Did you get the e-brake cables/brake lines with the rest of the conversion?
dude proportioning valves from the dealer ARE FUCKN outragous they want like 300 bucks if i remeber correcttly i went to a junk yard and got it for 15 bucks the minimum they charge for a part. you don't need the proportioning valve or the MC but your peddal gets soft. also if you purchase a integra MC you must get the integra BB
EGhatched
10
03-31-2004 08:45 AM
