JDM D15B cam and header???
Can anyone post a link to a reliable place to find a nice cam and a header for the jdm d15b engine. I need those because i want to build it up a bit. thanks
u can use same type cams/header that are made for any sohc d..from 1.5-1.6l..it just depedens on what kind u want u know.. i use my i/h/e off my D15b2 on my new jdm D15b vtec wich i am sell whole swap with si/tranny....and some mods on it....
Re: JDM D15B cam and header??? (vxhatch02)
If you're running the stock P08 ECU for the D15B you need a header for 88-91 D15/D16, it has an 02 bung where the stock D15B SOHC VTEC had it. If you run the P28 ECU then you can run any 92-95 D15-D15 Header because the 02 sensor is heated and is placed farther down the secondary.
