couple of questions about some EG hatch mods......i did search
ok guys, i have 2 questions and hopefully you can help me
question #1
will EG civic EX coupe doors bolt right onto an EG hatch?
question #2
will a 94-01 integra center console bolt right on to an EG hatch?
thanks for your time
question #1
question #2
Re: couple of questions about some EG hatch mods......i did search (temp)
Answer #1 yes i have done it the tricky parts is wiring the pass. door you will have to get both wire harness off the ex(the one that hooks all the power stuff to the main harness) you have to cut the pass. side. you can unhook the drive side and just hook it up the driver side will work instantly. all you have to do is wire the correct colors to both doors. it is not really that bad i did it all in about 2 hours wiring and all.
answer #2 i dont think so cause the center console will not match the eg dash.
you would have to swap out the dashes
the back part of the center console (with the armrest) will
bolt into your eg BUT it does not match up perfect....
I have it on mine and it looks fine to me
worth it just to have the armrest not to mention
the extra storage
the extra storage
Re: couple of questions about some EG hatch mods......i did search (EGinNY)
you can bolt up your arm rest in stock place but it looks cheesy because you are missing the other half of the dash. if you plan on changing out the dash for a teg dash you will have to relocate the center console forward
Re: couple of questions about some EG hatch mods......i did search (saleensolution)
Its one thing not to do a search before you post, but its even worse to lie about searching when you obviously haven't.
Re: couple of questions about some EG hatch mods......i did search (Jinya1004)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jinya1004 »</TD></TR><TR><TD CLASS="quote">Its one thing not to do a search before you post, but its even worse to lie about searching when you obviously haven't.</TD></TR></TABLE>
its one thing not to answer the original question and its another thing to be a total ******* dick head when you answer a post without answering the question, i did search, it turned up nothing.......*****
xXx Justin xXx
02-05-2003 07:13 PM
