Quick!!! Dash help
Old 02-10-2004, 01:57 PM
Jmorin's Avatar
Default Quick!!! Dash help
I am trying to remove my dash and the passenger side with the air bag seems to wanna not go,I removed all the screws and bolts i thought,can someone give me a run down on where they are located?,Also i need to unplug the airbag i believe?, which connectors i unhook?
Old 02-10-2004, 02:08 PM
Jmorin's Avatar
Default Re: Quick!!! Dash help (Jmorin)
Anyone??
Old 02-10-2004, 02:40 PM
salbaje's Avatar
did you take off all the screws underneath the airbag?? you can take off the dash with airbag intact.
Old 02-10-2004, 03:31 PM
TurboBumblBee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmorin &raquo;</TD></TR><TR><TD CLASS="quote">Anyone??</TD></TR></TABLE>
how do you expect someone to reply to the thread in less than 20 min????
just look up there really good it will all come out..
Old 02-10-2004, 04:43 PM
Jmorin's Avatar
Default Re: Quick!!! Dash help (hybrid94Si)
I dunno dude,but anyone else,all those screws up in there up in the glove box area?Nobody has any pics of those screws you should take out do they?
Old 02-11-2004, 06:08 PM
Jmorin's Avatar
Anyone else?
Old 02-11-2004, 06:15 PM
Grip's Avatar
there are 6 10mm bolts holding the dash onto the car..1 on each end, 1 under the big vent on top..and 1 at each lower end..1under fuse box ,1 under glove box,1 under pocket in center console area(directly under radio towards floor)..then remove the bracket behind the dash,then remove steering wheel,then remove guage cluster bezel,then remove guage cluster,remove hazard switch,remove dimmer switch,remove rear defrost switch,un clip wire harness,remove stereo,(im not sure for the poassanger airbag since idont have one but im guessing it is bolted on from the bottom) just look for them most likely they are real easy to get to) after that is done slide dash off
Old 02-11-2004, 06:23 PM
jolt-tsp's Avatar
Pry the airbag out before you take the dash off... pry against the crossbar. That should make things easier. Then just pull on the dash and find out where it's bolted
a lot of the bolt are very awkward to get to.
Old 02-11-2004, 06:40 PM
hndakd's Avatar
i had to pry mine out, just knock it around a little bit and find out where its bolted or hangin on
Old 02-19-2004, 02:19 PM
Jmorin's Avatar
Ok,I have done some screwing around and shaking,I just really dont wanna screw things up,So i posted up some pics if this could help?
Old 02-19-2004, 04:32 PM
Jmorin's Avatar
Pretty pretty please......
Old 02-19-2004, 04:35 PM
si foo's Avatar
unhook the yellow connector, 4 screws on the airbag bracket 10's, then there's 4 more screws inside under the dash that holds the airbay on the dash, they r 10's too nuts. then lift the airbag up off the dash...
ej6hatchie
Paint and Body
05-14-2008 09:48 AM
SL0Wcrx
14
01-16-2007 03:55 PM
spoonInspired
07-29-2005 06:53 AM
vinniescrx
11-15-2004 08:06 AM
HybridGSR1
06-20-2003 05:31 AM
Quick Reply: Quick!!! Dash help
