Problem with lights
Problem with lights
I just got a 92 civic si and for some reason when I turn the headlights on the park lights turn off and the lights for the dash also go out, Is this someone else has had a problem with?? Quick fix? I looked at fuses but didn't see any blown, so i'm stumped for now.
Thanks in advance for any help.
The weird thing is if just the parking lights are on the dash lights work and the parking lights, hell even the dimmer works when just the parking lights are on, it's just when the headlights are on dash lights and parking lights are scared to show
Re: (ChargedLude97)
Headlights, aftermarket harness and relays. Dimmerswith, transistor 3.99 at radioshack. Could have something to do with the comboswitch also.
Well no luck, last night I unpluged the headlights, no luck there. Swapped out the dimmer switch with another one I had, and then switched back to some stock headlights but still no luck. Any other ideas?
All fuses looked good. Even weirder is if i'm on the park lights and hit the brights they(the park lights) stay on, but once i switch it to the headlight setting the park lights turn off. I'm not sure what it could be, i'm gonna order a light console switch and see if that might be it.
Hmm i must have two bad dimmer switches then because i swapped them out and it still didn't work, well the combination switch will be here later today so ill put the new one of those in and see where i'm at. I guess i might just have to buy another dimmer
LSteggyguy
12
05-15-2016 03:37 PM
kerubin
08-21-2012 09:26 AM
Vtec Civic 93
01-05-2011 09:28 AM
ttrinh77
01-03-2005 06:45 PM
