Cranking Car problems.. need Help !
today while i was driving it on the road reving it up past 3k i can feel the car misfire .. it seems like it wasnt reciving any fuel. After i park it .. came back an hour later it wouldnt crank up after about 5 tried it crank up i let it warm up and went about 100 ft and it die. After that couldn't crank up at all at first i thought it was bad spark plugs but then it seems like it's reciving connectivity so i figure it's the fuel pump im stuck now the car crank but will not START can i actually mess up the timing belt if crank to much? Im thinking it's the fuel pump i'll check it out to morrow but im worry about the timing belt can i mess it up
Re: Cranking Car problems.. need Help ! (EGkwazhimoto)
i dont think ur timing will be fucked. check fuel pump, plugs(again) and wires. cap. fuel filter, or even ur battery.
Re: Cranking Car problems.. need Help ! (HXvtec)
i seem to hear the fuel pump Pump but when i tested the spark plug while #4 was out it had no spark Looks kind of burn up to it was all black had to wipe it off. could it be the spark plugs?
HondaPartsHero
02-06-2011 01:55 PM
plantmylotus
10
10-14-2008 10:49 AM
blaxican05
09-29-2006 08:23 PM
naptownrex
19
02-10-2006 07:41 PM
gokuson
06-30-2002 06:14 PM
