brake lights and buzzer for headlights not working
Old 02-28-2013, 11:07 AM
zacheryleatherw's Avatar
Default brake lights and buzzer for headlights not working
My headlights and everything else work just my brake lights don't come on and the fuse is good. Also when I turn the headlights on without the key in the buzzer doesn't work. Oh and I have a 99 civic ex
Old 02-28-2013, 11:31 AM
Default Re: brake lights and buzzer for headlights not working
And now I have to shove my key in that little spot next to my shifter to shift from park
Old 02-28-2013, 11:38 AM
belairbrian's Avatar
pretty sure the brake lights and the shifter are related. Likely the brake switch. The brake switch releases the shift interlock so you can shift.
Old 02-28-2013, 04:17 PM
Well its happened before except I could shift out of park and I'm pretty sure the buzzer worked. I tried to change out the switch and that didn't work. So I chased down the wire and I guess from moving the connector it made it work properly. Today I needed to fix it fast so I ran a wire from the switch past that connector behind that panel on the drivers side. But there still not working and I can't take it out of park unless I put my key in that little slot. So tomorrow I'm going to reconnect that wire and go from there
dsjetergirl
44
04-12-2015 07:31 AM
tabartis
12-21-2011 09:52 AM
fourlug
05-07-2011 01:46 PM
curtie94
03-21-2011 08:27 PM
DC5_lov3r
14
08-07-2007 01:24 PM
Quick Reply: brake lights and buzzer for headlights not working
