Motor Mount help
Re: Motor Mount help
Inspect them to see which have failed and replace them. Typically the rear trans mount and the left and right torque mounts die on Civics.
http://www.rockauto.com/
These for the motor? http://www.ebay.com/itm/AVID-ALUMINU...891da9&vxp=mtr
and what should I search for the tranny mounts
Details on car. Stock? mods? daily driver? Planned use?
Did you see this in the ebay add "These mounts are quite stiff and will bring a good bit of vibration through the chassis"
these fit with a gsr tranny? http://www.ebay.com/itm/ROCA-Civic-S...d927e4&vxp=mtr
What transmission you have doesn't matter. A B is a B.
twenty, there's a reason you can't make your own thread yet. You're expected to do some searching and reading. Read the FAQs sticky.
...Couldn't find what? The eBay link you posted has ALL of your replacement mounts. The only mount it doesn't have is the rear T bracket mount, which is solid. You don't need to replace it, ever.
should I get this and those two avid mounts for now? http://www.ebay.com/itm/DEA-PRODUCTS...873a5b&vxp=mtr
im thinking about getting these. http://www.ebay.com/itm/Hardrace-Mot...4425e8&vxp=mtr
Then stop shitting up the thread. Thanks.
OP, this is what you want to buy. Stop being so indecisive. Don't waste your money on HardRace mounts for your never-tracked, stock DD. There is absolutely ZERO reason to spend $500 on mounts on your factory car.
Retired Moderator
or you can look to HardRace mounts.
cheaper and great quality.
http://www.velocityshop.com/product/...civic_326.html
[626]95-GSR
11-20-2005 09:15 AM
