HELP!!! ENGINE SWAP HONDA CIVIC EX
i have a 1995 honda civic EX coupe with a messed up engine there is a hole in the block i have a good older engine it is a 1990 acura integra 1.8L 4-cyl DOHC 16 valve engine i honestly dont know to much about cars but i need to know if this will work without needing to get the computer and the wire harness for the engine but if i do need the computer and wire harness what do i get?
Re: HELP!!! ENGINE SWAP HONDA CIVIC EX
...Really? If you spent two days on Google, you weren't searching correctly. I'll give you a hint: 95 civic motor swap. Alternatively, you could read the FAQ's sticky, because there's a HUGE chunk of information that will tell you EXACTLY what you want.
so your wanting to know how to put a b series in a 95 honda civic? how do you not find that in 2 days of searching....
https://honda-tech.com/forums/hybrid-engine-swaps-18/definitive-guide-gsr-eg-swap-2976738/
took me all of 30 seconds
Look it's simple. You got the engine get the computer for the same year. What ever jumper cables you need and a wire harness for that engine. And do research.
Bifferson
01-13-2016 10:54 AM
prettypegagirl
10-31-2011 05:43 AM
