front left caliper problem
hello H-T
few days back i noticed that my front left wheel is stuck so i remove it and open the caliper and bought a caliper kit .so i changed the seal and test the cylinder wheel if its returns after pushing the pedal and it works fine so i fit it again and i drive the car for a test every thing was fine but yesterday same problem .
my question is any other part will cause this problem like the MC or brake lines or the brake fluid distributor ?
note i bleed the fluid several times . HELLLP PLS
Re: front left caliper problem 99 civic vti
hello H-T
talks to himself
The caliper piston isn't retracting?
Are you sure you cleaned the seal grove thoroughly and reinstalled the seal properly?
MurtazaDSM
10-19-2012 09:21 AM
superhatchbackbros
06-07-2007 09:58 PM
