New harness help! Misfire/check engine light
Old 03-05-2013, 08:49 AM
MrWestCoast's Avatar
Icon2 New harness help! Misfire/check engine light
Never mind I got it
Old 03-05-2013, 09:34 AM
Seagull Management
94EG8's Avatar
Default Re: New harness help! Misfire/check engine light
I guess my first question is why did you use this harness? What was wrong with the stock harness?
Old 03-05-2013, 10:16 AM
Technical Hero
HondaPartsHero's Avatar
My question is why on earth anyone would make a harness for an OBD0 engine in an OBD2 vehicle. There's just all sorts of wrong there. I'm actually not even sure how the car runs at all.
Old 03-05-2013, 11:19 AM
It was a wire tuck. So used that harness cause it was cleaner.
Old 03-05-2013, 11:21 AM
Sorry I meant only the injector clips were for obd0. The dizzy and alternator clips were for obd1. So I bought the obd1 to obd2 conversion harness' so u could use my obd2 dizzy and alternator.
Old 03-05-2013, 03:55 PM
Technical Hero
What was the solution?
Old 03-18-2013, 03:04 PM
well to fix the check engine light, i didnt know the extra wires on the rywire harness were for that. each one was for the check engine light, rpm, and something else i forget.
but i still cant figure out why it sounds like its misfiring. did a compression test and everything was good. no check engine light. i need to get a fuel pressure gauge to see where im at. only at idle is when u can hear it
JJGL-EF90
11-26-2010 10:30 PM
B18CUL8R
12-23-2008 09:58 AM
hfrex
12-14-2008 08:35 PM
chameleon
04-18-2008 03:26 PM
89_crx
10-01-2004 10:16 PM
Quick Reply: New harness help! Misfire/check engine light
