Bad axle/bushings & mounts
I have a 93 del sol with a 1.5 in it. I'm assuming it's just a bad axle but I want to make sure. It just started the other day when I turn left I can hear clicking from the passenger side.
Also, since the car is 20yrs old I'm looking at replacing all the suspension bushings. Is there a master kit out there and what would you all suggest. It's just a daily driver and I want it to be somewhat smooth ride.
What about motor mounts? I want to replace mine and all I can seem to find are swap mounts for a b16 etc. Would you all go with polyurethane mounts or try to find stock ones?
Re: Bad axle/bushings & mounts
you can drive on a clicking axle until it starts clicking when you're driving straight, that's when they start being an issue and need replacement.
you should be able to find motor mount inserts instead of replacing the whole mount.
Personally I have not ever used inserts so i cannot speak for those. I would suggest just getting factory replacement motor mounts and oem bushings if you desire a smooth ride. Polyurethane mounts (depending on which kind of urethane you choose) can make your car vibrate all the time and it can be noisy and uncomfortable, it all just your preference though. I would ask a friend or someone you know who has them in their car and see how it feels, go for a ride.
Personally I went with oem mounts and polyurethane suspension bushings, simply because to me it was the cheaper route and for weekend track use you can't go wrong, I don't even really feel the difference too much myself in the ride quality. But I'm very picky about vibrations in the interior so the oem mounts make the car super smooth in city.
As far as the axle goes? I would replace it to be safe and save yourself the headache down the road. It's only like 50 bucks and I'm sure you can find a used one around for cheaper, just go buy an axle nut from your local auto parts store.
So if I decide to just buy OEM mounts can you all tell me how they are labeled? I have been looking them up and I'll see one labeled front left mount, or rear mount and to me it doesn't make since. The one that says rear mount doesn't look like it goes in the rear at all so maybe I just don't know how all the mounts are labeled.
That's what I heard. How are you doing it? I've heard some heat, saw saw, screw driver, and a big hammer usually worked.
96hondab16a
14
04-11-2006 05:24 AM
Thunder Cat
11-13-2005 04:56 AM
