bulb is good but no check engine light
Alright I stumped. I have a 2000 civic lx with a 2000 b16 swap. When I turn the key on check engine light does not light up and when I plug my scanner in it turns on but reads nothing. I checked all fuses and they are good. Does anyone have any ideas anything would be great thanks.
Re: bulb is good but no check engine light
So you have no codes, but your CEL doesn't work. I'm assuming you've pulled the bulb and resistance tested it alone? Have you tried voltage testing the bulb contacts on the cluster?
Yes bulb is good. And when I plug my scanner in the scanner it self
Turns on but there are no codes but I know this can't be true because I still haven't wired in my secondary o2
Stock b16 ecu I can get a spare but according to a friend who owned the car prior he had the same issue with the stock engine and ecu lol so I'm stumped
If you loved me, you'd all sell me your magic cards to me today
So you have no CELs and the scanner pulls none? If so is it only the light that is broken, perhaps something wrong in the cluster itself.
does the car run? or start? cause the one time my check light wouldnt come on, and my car wouldnt start it was the ground on the thermostat housing...
rudyndrew
01-05-2011 05:32 PM
1320king
07-22-2007 12:32 PM
Project_EK
08-13-2005 04:08 PM
