Eg hatch Si electrical problems??
Hi I have a few problems with my hatchback. Its a 1994 eg hatch si model. The problem is my right side power side mirror doesn't work, my right front speaker doesn't work. My right rear speaker works. Also does anyone know which is positive on the door speakers wires? The blue or white wire? When I wires my front driver side speaker I did Blue positive and white neg. the speaker is pretty faint . Can anyone help? Haha thanks in advance.
Re: Eg hatch Si electrical problems??
If you open your door and look on the side of the hinge, you will see a bunch of wires running into the door. It unplugs from the door. I would check that plug there for no/poor connection or dirt and corrosion since it seems like everything in that door isnt working.
swap again the speaker wires blue as - white as +
and check if the sound changed if not track the wires maybe one of them is cored and touching some metal under the dash
dweston
12
03-19-2013 03:27 AM
