Need Help! my car dies when i hit the gas pedal
Car ( civic 98 ) doesn't want to rev up 3000rpm, if a hit the pedal like almost 2 seconds the motor just dies. Pull out the map and tps same problem just revved higher to 5000rpm , later on day i will try to get ecu code (oem obd2 ecu)If anyone have an idea for whats is the problem I really appreciate.
Re: Need Help! my car dies when i hit the gas pedal
Pull the CEL codes. Jot them on a piece of paper.
Reset ECU to clear the codes.
Run engine until CEL remains on.
Pull codes and post them.
I doesnt have any obd2 scanner so i just jump with a cable the blue plug and get the code: 7 , 14, 22, 41, 54... my b20 doesnt have crank sensor yet, and also o2 sensor .. idle are connected but doesnt know which color are the cable ... , thanks!
Technical Hero
There are at least 3 OEM 98 ECUs: P2P (D16Y8), P2E (D16Y7) and P2N (D16Y5), none of which will run a B20 properly. You need an OBD2a PHK ECU from a CRV or at least a P75 from an OBD2a Integra. Code 22 is a vtec code so you shouldn't be throwing that on the P06 ECU unless it has something to do with the chip. For the code 14 you'll have to do a 3 to 2 wire IACV fix if you haven't done so.
My car is civic EX, Iacv fix, which plug is it? I have an unplugged one which have 3 cables, is nothe speedmeter or tps and map, what i have to do with it?
Lou845
07-11-2012 02:53 PM
crvtt96
06-06-2004 04:00 PM
