WHAT IS THE BEST?
Old 08-07-2004, 10:21 PM
BrianDelSol's Avatar
Default WHAT IS THE BEST?
What poduct is the best for cleaning your valve cover completely before painting it? Mine was not painted so i don't need to strip paint...
Old 08-07-2004, 10:27 PM
ghettochild's Avatar
Default Re: WHAT IS THE BEST? (BrianDelSol)
either strip it with air craft coating remover or sand blast it or put it in a vat.
Old 08-08-2004, 12:14 AM
Street Ghost's Avatar
Why do you want the best just to clean a valve cover? I would say brake cleaner or some Simple Green would clean it plenty. I've painted a few valve covers and all I did was strip the paint, sprayed it down with water and wiped it dry. Paint still holds even under a hot, turbocharged engine bay.
Old 08-08-2004, 02:49 AM
Db1 Supreme's Avatar
Default Re: WHAT IS THE BEST? (JDM Ninja)
aircraft remover
Old 08-08-2004, 03:03 AM
Ajax's Avatar
Depends on the valve cover... on my SOHC simple green didn't do ****. Works wonders on the rest engine bay though. to simple green. ^_^
If its the SOHC I think you could just use an SOS pad or something to get it clean, anyone disagree?
Old 08-08-2004, 03:17 AM
TurboEH2's Avatar
Default Re: WHAT IS THE BEST? (Ajax)
i was gonna say brillo pad. but sos works also. it also creates a better surface for the paint to stick too. just make sure u rinse it good.
Old 08-08-2004, 04:12 AM
menkio's Avatar
Default Re: WHAT IS THE BEST? (VTECschmetec)
aircraft remover. end of thread
Old 08-08-2004, 06:39 AM
deepnite's Avatar
Default Re: WHAT IS THE BEST? (DewMota)
preping anything will need to be clean d..the surface roughen d up a bit..use a fine sandpaper..then the paint needs something to stick to..
prime with a heat resistent primer..then paint
lax1089
11-07-2007 10:52 AM
HOCSA
Paint and Body
05-18-2007 01:35 AM
Smeeg Heed
08-21-2004 02:23 PM
vicz
10-21-2002 10:00 PM
Quick Reply: WHAT IS THE BEST?
