how do I? dsm injector wire up on obd2 96 civic for turbo
Ok im working on a 96 civic with a f23 (same as a f22 or h22) with p28
im putting turbo on it
I purchased dsm injectors and I need to know how to wire them to a h23 resistor
Im new to this kinda wire job and I cant find anything other than homemadeturbo.com’s pain in the *** one.
On the resistor I see a red wire and 4 black wires.
Im guessing the red is just a 12v
And each black is for one injector, is there a certain order or just hook it up?
Now to the injector clips theres to wires, what wire goes to what????
Using the 96 civic obd2 harness (on a p28)
Injector wire colors
yellow yellow/black
Blue yellow/black
Brown yellow/black
Red yellow/black
Im guessing the yellow/black is constant and the other one is the injector pulse???
Can someone explain????and how I would wire this up
yellow yellow/black
Blue yellow/black
Brown yellow/black
Red yellow/black
Re: how do I? dsm injector wire up on obd2 96 civic for turbo (BOMBCRU)
now im not positive on this, but when i installed resistors into my obd1 d16z6, the injector pulse comes via the grounds that go to the ecu, and the other wires are just power( i wired inline resitors into the power wires and not the grounds), so by this, the resitors are inline wit hthe power and not the grounds.....
I've got a link for instructions in here.
https://honda-tech.com/zerothread?id=889398
Wiring up the resistor box is the same. Only extra thing you have to do is swap out your injector clips.
Re: (T-RO)
i was reading all i have to do is cut into the clips and they will pop on
i looked on my harness i found the dead clip its actually under the intake manifold for the 96 but it should still work just not as clean
thanks
thanks
95dc2teg
12-15-2008 08:47 PM
Frozen E
10-28-2004 08:51 AM
