what is different between those o2 sensor?
do you think my o2 bad? and which one i should use
here my problem i drive 92 ex 4dr i don' know is the o2 bad or not but it seem like they burn alot gas i put like about 10.5 g each time like for about 200-250 mile local and freeway with 4 17" stupid whee. so my problem is if my o2 is no good which one i should use buy from the button of list .
from autozone
BOSCH
O.E. TYPE 13249 3 MO $169.99
BOSCH
UNIVERSAL 15734 3 MO $54.99
from kragen
Beck/Arnley 1564015
Oxygen Sensor: Pre catalytic converter
Lifetime Limited Warranty Weight: 0.3 lbs. $115.99
Beck/Arnley 1568400
Univ Type Oxygen Sensor:
Lifetime Limited Warranty Weight: 4.1 lbs. $129.99
Bosch 15734
Universal Type Without Connector; 4 Wire; Heated; Before Catalyst
1 Year Replacement Warranty Weight: 2 lbs. $89.99
Bosch 13249
OE Type With Connector; 4 Wire; Heated; Before Catalyst
1 Year Replacement Warranty Weight: 3.5 lbs. $304.99
HOnda dealer
is about 235
from autozone
BOSCH
BOSCH
from kragen
Beck/Arnley 1564015
Beck/Arnley 1568400
Bosch 15734
Bosch 13249
HOnda dealer
is about 235
crxaddikt
02-04-2013 04:02 AM
