Heat and Idle issue
Heat and Idle issue
This is what i have that is the motor
1995 Civic EX (D16Z)
JRSC (9lbs boost)
JRSC Fuel Pump
JRSC Fuel Pressure regulator
AEM Intake (NEW)
MSD 6 With boost retard
MSD wires
V-AFC
Gude Throttle Body
ACT Clutch w/ Flywheel
99 Civic Headers
This is what i have replaced in the past week.
Radiator
Radiator cap
Timing belt
super charger belt
power steering belt
Honda Metal head gasket
Honda water pump
Cap& rotor
Denso Plugs
Injectors (stock)
Fuel rail (stock)
AEM Intake
Thermostat (170 degrees)
02 Sensor
New oil change
Coolant flush
IACV
With all these things replaced I still have a odd idle speed when at a complete stop about 1500 rpm if i hit the gas real qwick it will idle at 900 rpm. still to high i should be 650-750 rpm.
ISSUE 1
When i get on the freeway and boost it reall qwick it will idle really high when i put it in Nuetral @ 4000 RPM and i have to down shift to get it down from that.
Issue 2
I also have a cooling issue as well.
The issue being it will heat up a past way past 210 Degress then i will have to turn on the heat to disipate it. We did a correct 50/50 mix and let it sit to get air out of the lines. Also hiiked a pressure tester to the coolant system it help like a champ @ 17lbs
Issue 3
Air/Fuel
Replaced the O2 Sensor and my gauge says that i am runnig all the way lean doesnt even read at all. When i do start from the morning at a cold start it will go up but only half way sometimes more but a mile down the road it drops Big time all the way so it doesn not read.
I have tried 3 O2 sensors and all the same senario and i know the gauge is right because my car runs like poo with no fuel. There have been a couple and i do mean a couple of times it went all rich and pulled like a scared puppy
So i am at a losing point and cannot think of anything can someone help ? Thanks in advance.
Any suggestions would GREATLY appreciated
Modified by hondaman2 at 12:08 PM 8/8/2004
JRSC (9lbs boost)
JRSC Fuel Pump
AEM Intake (NEW)
MSD wires
V-AFC
Gude Throttle Body
99 Civic Headers
Radiator
Radiator cap
Timing belt
super charger belt
power steering belt
Honda water pump
Cap& rotor
Denso Plugs
Injectors (stock)
Fuel rail (stock)
AEM Intake
02 Sensor
New oil change
Coolant flush
IACV
ISSUE 1
Issue 2
Issue 3
Air/Fuel
