Single cam swap(lol)
I have a civic hx, if i swap an ex head on it, and an ex exhaust manifold on it, will that give me more power?? i know the vtec on the 2 are different types so i was wondering if anyone knows.
Re: Single cam swap(lol) (snowpunkfu03)
its called a mini-me....heres 2 nice writeups...
one for a 6th gen https://honda-tech.com/zerothread?id=735196
one for a 5th gen https://honda-tech.com/zerothread?id=735196
read away
read away
Re: Single cam swap(lol) (JD95hatch)
i just bought an hx. my plans are to swap in a b18b(ive got my reasons ), but i plan on putting a z6 or y8 head/mani on my y5 block to use as a daily driver motor. it should grab you a little more power, but you will loose the roller rockers . while this might not give you more power, it should help acceleration- get an ex tranny!! closer gear ratios are helpful in going faster.
you might run into problems with the stock harness and using the p2n ecu( i think the hx will only run on its own ecu)......sorry i cant help you more then this, but ive just started to get into this idea myself. good luck
goula SOS
08-10-2003 11:29 AM
