Here's a question - will US odometer swap into JDM cluster?
Would I be able to swap out the odometer from my US cluster into a JDM cluster? And if so, what is it that determines whether an odometer reads miles or km? Would a JDM cluster with a US odometer still read miles?
Or should I just not worry about it?
Re: Here's a question - will US odometer swap into JDM cluster? (BrewerHatch)
When I say odometer, I mean the entire assebly behind the guage face.
Re: (Split Image Prez)
The speedo needle should be calibrated the same, just the guage face is different. My only concer is the odometer. Will it turn in KM's or miles?
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">arent the faces reversed? Trip and odo placement I mean.
If thats the case then it couldnt work...I think</TD></TR></TABLE>
yes itll work and itll read miles. since it has the miles gear in it for the vss. i forgot who did it but someone had the us odometer and the rest eg6 cluster. i believe it was in a honda tuning. ill look a little later. and post pics.
Re: (BrewerHatch)
im not sure if i understand your plan here but i think you are going to swap out your entire US speedo/odometer assy into your JDM cluster.... i doubt this will work, its the printed circuit behind the cluster that determines whether the odometer reads in mph or kmh. Also your needle will not be reading mph accurately.
you could swap printed circuits as well as speedos and that would work, but be careful when swappin printed circuit because they are easy to **** up. i over-torqued the screws
Re: (DxHatchback)
It works fine. You can swap all the gauges out, just did it for my friends broken gas gauge. The only thing you might run into a problem with is the DC2 94-97, and DC2 98-01. You will need to find a matching year for those.
Re: (2.0L EK)
negative
1 st off there are no screws on thye face of the jdm eg6 cluster ,
when there are on the usdm. So how can you change km to mph when it will snap i tried and it cant be done Maby jdm gsr are diffrent but jdm eg will not
Re: (JESUSDREAD)
I'm pretty sure everyone is talking about swapping out the entire gauge not just the face. Swapping out the face would make no sense, the MPH and KPH are in completely different locations
Re: (2.0L EK)
if you want a black guage in the middle go for it
infact you gonna have to use your usdm cluster housing & switch every part (meaning)remove pins w fork and use jdm faces w usdm backing in side a usdm cluster and cut where your milage will fit !
id just rather roll in km and w a srs light attached!
Re: (2.0L EK)
Haha, I was only talking about swapping the odometer assembly behind the guage face. JESUSDREAD brought up a good point:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JESUSDREAD »</TD></TR><TR><TD CLASS="quote">1st off there are no screws on the face of the jdm eg6 cluster</TD></TR></TABLE>
Looks like it's a no go.
Re: (JESUSDREAD)
ummm no need to get vicious kiddo. who pissed in you corn flakes? also i have seen this done to a EG6 (jdm sir) cluster in the ENDLESS track car. so do not tell me it cannot be done.
Re: (VTECschmetec)
w- a cdn LOL were talking usdm no need to hate im just relating maby im wrong but my usdm and the other jdm are diffrent were not talking about cdn i know that one will work !
Re: (JESUSDREAD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JESUSDREAD »</TD></TR><TR><TD CLASS="quote">w- a cdn LOL were talking usdm no need to hate im just relating maby im wrong but my usdm and the other jdm are diffrent were not talking about cdn i know that one will work ! </TD></TR></TABLE>
huh what????? wtf is CDN do you mean CDM? i wasnt hating, i was stating what i know.
