00' B18C5 INTO A 94 CX HATCH (4 ?'S)
Well I hope you swap guru's can answer these questions for me, I did a search and checked out the faq's with no luck...
1. Can I just plug up the connectors and thats it for the wiring? There's an extra plug with 3 wires on the passenger side of the engine that the civic doesn't have, whats that connection for and can I run without it?
2. Can I use the existing fuel system with the new engine, I will swap the fuel pump but can I use the civic's fuel filter. (I dont want to change it unless I have to because the inlet point is different and I would have to swap the whole line back to the fuel tank.)
3. How do I swap the brake line proportioning valve? I don't want to run abs, the civic's proportioning valve has 2 inlets 4 outlets, the R's prop valve has 2 inlets 2 outlets, what should I do?
4. Can I just swap the whole dash? the connectors are different (I think) where it plugs in, what are my options here?
any help is greatly appreaciated as these issues plague my thoughts, thanks in advance guys.
Chris
Chris
Re: 00' B18C5 INTO A 94 CX HATCH (Evil_Wizard)
https://honda-tech.com/zerothread?id=131949
Took me more time to respond to your ad then it did to find the damn article.
Re: 00' B18C5 INTO A 94 CX HATCH (ITR 1007)
Whats even worse is that you have been here for 1342 days and you still have to ask useless friggin questions rather then do a search.
i dont think you looked hard enough...... i have like 5 saved in my fav's... here is this one the most informative but you must read the whole think https://honda-tech.com/zero...age=1
Re: 00' B18C5 INTO A 94 CX HATCH (95sihb)
Well i agree that one should give most people here enough info. But seeing as he cant find the search page. I figured Tom's very detailed b series swap instructions. Might be a little more useful. Now if we could only get Tom to go and hold his hand.
Prevail
11
01-07-2003 11:05 AM
