Compression Ratio Question for EX
Old 08-08-2004, 07:50 AM
mushu315's Avatar
Default Compression Ratio Question for EX
how do i mess with the compression ratio for Civic 99 EX?
I want to increase it
mushu315 is offline
Old 08-08-2004, 07:54 AM
boosted eg's Avatar
Default Re: Compression Ratio Question for EX (mushu315)
well other than buying higher comp. pistons which is the best way to increase compression. you can also get a thinner head gasket or mill the head which i recomend not doing b/c not many shops will do a great job on that.
boosted eg is offline
Old 08-08-2004, 08:31 AM
Risky Business
BauleyCivic's Avatar
Default Re: Compression Ratio Question for EX (boosted eg)
Some D16A6 pistons would be a good idea, and maybe milling the head a little bit
BauleyCivic is offline
Old 08-09-2004, 05:43 PM
mushu315's Avatar
Default Re: Compression Ratio Question for EX (BauleyCivic)
just the pistons will do? or do i need rods too?
how do i know if the ring is worn down and needs replacement?
mushu315 is offline
Old 08-09-2004, 05:45 PM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mushu315 &raquo;</TD></TR><TR><TD CLASS="quote">just the pistons will do? or do i need rods too?
how do i know if the ring is worn down and needs replacement?</TD></TR></TABLE>
Uhh...do you have any idea what you're talking about?
Old 08-09-2004, 06:08 PM
mushu315's Avatar
no, that's why i'm asking
mushu315 is offline
Old 08-09-2004, 06:18 PM
simplypinoyy's Avatar
Just replace the pistons u shouldnt really hafta replace the rods unless u really want to but yours should hold up well... But for higher compression take ur metal gasket and remove the middle layer then u get a thinner headgasket thats the cheapest way to go unless u go n buy a thinner headgasket. But basically pistons to raise the compression and some of the other stuff that people here already suggested.
simplypinoyy is offline
bseriesEF
10
11-13-2006 04:37 PM
BlkChryKord
11-06-2006 11:35 AM
BLK99VTECR
16
01-19-2005 06:32 PM
EGB18
07-14-2004 10:36 AM
HaTcH_BmX
12
10-01-2003 06:25 AM
Quick Reply: Compression Ratio Question for EX
  • Ask a Question
Question Title:
Description:
