NOOB ? _VALVE COVER REMOVAL_SOHC
NOOB ? _VALVE COVER REMOVAL_SOHC (FAST HELP)
I took out all the visible bolts, what else do i need to remove to get my valve cover off, spark plugs? Anything?
PLEASE HELP, IT'S ON THERE HARD, I JUST HAD SURGERY, IS IT JUST HARD TO PULL OFF?
Modified by BrianDelSol at 2:56 AM 8/8/2004
Re: NOOB ? _VALVE COVER REMOVAL_SOHC (BrianDelSol)
5 bolts unscrew on the cover itself, then a few off to the side, 1 left and one right i think holdin clamps..then u gotta yank the bolts outa place....its prolly just a lil stuck because the gasket is tight...be extra carefull and wedge a flathead betwwen gasket and cover....and pry up untill it breask the seal....thats what i did.
Re: NOOB ? _VALVE COVER REMOVAL_SOHC (JD95hatch)
also the best thing you can ever get for you and your car ids a Haynes manual....pick one up at your local advance or auto zone...everyone here will agree with that too....they help a hell of alot
Re: NOOB ? _VALVE COVER REMOVAL_SOHC (92RED Hatch)
I figured it out, i wasn't pushing hard enough because of my surgery im a bit weak i guess, thanks for answering my noob question.
