Adjusting clutch biting point?
I have to push my clutch like halfway down before it kicks it into neutral. This is annoying becuase for quick shifts I basically have to ride around with my foot on the clutch all the time (holdin it halfway down).
Is there any easy way to adjust it so it bites when i push the clutch down like 10% instead of like 60%?
Re: Adjusting clutch biting point? (turbotime)
You could adjust the clutch push rod located on the clutch pedal. That adjusts the amount of play in the pedal, but that is only if you have a hydro trans. I don't know about cable transmissions.
Re: Adjusting clutch biting point? (Two_K Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si »</TD></TR><TR><TD CLASS="quote">You could adjust the clutch push rod located on the clutch pedal. That adjusts the amount of play in the pedal, but that is only if you have a hydro trans. I don't know about cable transmissions.</TD></TR></TABLE>
is that only located on hydro trannys?? is there any other way to adjust for cable trannys??
thanks
thanks
i just went out and looked at my pedal, there is the rod behind it with a threded end and a button type threaded thing in on front of the pedal. Which of these two do i tighten? The push rod, the button thing or both?
how do you adjust the push rod? do you need to remove the cotter pin and dowel attaching it to the pedal and then spin the thing that the dowel goes through ?
verbal_assassin
11-28-2005 08:45 PM
I8ayellowcrayon
08-23-2004 07:18 PM
