help car wont start , throwing code 22??
OG triple OG
i went back to my car after it shut down 6 days ago . i go to start it befor i try anything and i hear signs of life but still no good , i have to floor the car to have it started , like its not on all cylinders or somthing . its throwing a code 22 every time i try to start it , even if i reset the ecu im stumped , i change the cap , rotor , coil , injectors are new rc440's.
Re: help car wont start , throwing code 22?? (Hella_JDM)
22 = vtec oil pressure switch. Check the wiring, maybe there is a break in it somewhere, and test to see if you have a bad switch.
It will not prevent you from starting so you need to look into that further.
Getting spark/fuel?
Getting spark/fuel?
OG triple OG
Re: help car wont start , throwing code 22?? (Echo7847)
im only getting fuel out of injector 4???? what the **** is that about...... ive checked the wiring and they look good , they are 4 month old rc440's i dont get it.
This should be obvious......but when you turn the on the ignition you should hear the fuel pump kick on.....
If so move to injectors and check power & fuel.......then it should only be spark from there.....
Good Luck
Good Luck
OG triple OG
Re: help car wont start , throwing code 22?? (onejdmchris)
i still need to double check the wiring . but what i did was whiped all the plugs dry and put them back in , i cranked it like 5 times . then pulled the plugs again , only wet plug was #4 . so i dried that plug and put it back in . i pulled the connector off of #4 and put it on injector 3 and cranked 5 times . that injector was dry . i still need to double check the wiring , but is it safe to say that 3 of my rc440's took a crap?
mike93eh
36
12-18-2004 01:18 PM
ATS*Mark
08-09-2004 07:19 PM
