how to make fit on a ek crv five lug?? can i put on an ek???
Re: (*****StEr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****StEr »</TD></TR><TR><TD CLASS="quote">probably thinks its cheaper. pretty sure crv 5 lug wont fit. itr 5 lug is direct fit. not that hard if you know what your doing.</TD></TR></TABLE>
everything is direct fit when you have time, money, and patience.
Re: how to make fit on a ek crv five lug?? can i put on an ek??? (gulfinc)
front CRV 5bolt/hub knuckles are the same as JDM 98+SpecR ITR, also uses 36mm axles. back might work by swapping hubs into the civic trailing arms but it would need to be 2wd crv model and you would need to have some sort of brackets possibly made for the calipers to be mounted. (btw rear crv uses drums)
Re: (*****StEr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****StEr »</TD></TR><TR><TD CLASS="quote">just get itr 5 lug, much more easier and saves time. super brakes!</TD></TR></TABLE> give this guy a break itr 5 lug costs at least $500 ? if you an find a crv in the junk yard you could probly get every thing for $250? same **** but the calipers right?
Re: (electronb16si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimbeamsEK »</TD></TR><TR><TD CLASS="quote"> give this guy a break itr 5 lug costs at least $500 ? if you an find a crv in the junk yard you could probly get every thing for $250? same **** but the calipers right? </TD></TR></TABLE>
I looked into this swap about seven months ago. The front suspension from a CRV w/abs is going to run you about 7 or 800 bucks. Save up and get an ITR five lug. If you search the archives, i'm sure you'll find my WTB threads for front CRV parts. Get the ITR.
EKtypeRhaTcH
04-03-2006 01:06 AM
::MUGEN::INTEGRA::RSi
52
05-13-2003 02:49 PM
