F20B homework
F20B homework
i have an F20B motor and i've been reading a lot of the threads on this motor in the archives. i know there is not a lot of info out there on this motor and thought it would be helpful to show all the info i got. the majority of the info is for the manual cause if you have this motor, it's the one you should have. if i made any mistakes, feel free to make any corrections.
F20B
basically a destroked H22
identical blocks/different sleeves/different internals
the base motor for the F20C (S2000)
mugen needed a motor that was a maximum of 2.0 liters to compete in the japanese touring car class
in accord/troneo (CF4) (JDM)
SiR (automatic)
SiR-T (manual)
SiR = sport injected racing T = troneo
OBDII - open deck
200 ps/145 tq
200 hp @ 7200 rpm
145 lb-ft @ 6600 rpm
vtec @ 5500 rpm
redline @ 8200 rpm
11.0:1 compression ratio
type-s cams/valvetrain/porting
iron sleeves - can use forged internals
block = 85 mm bore/ 88 mm stroke = 1997cc
rod specs:
length: 145mm (5.709")
BE (big end) bore: 48mm (1.809")
BE (big end) width: 23.75mm (0.935")
pin bore: 22mm (0.866")
pin width:23.87mm (0.940")
H22A cams, headers, valvetrain, etc. can be used
F20B
SiR (automatic)
SiR-T (manual)
OBDII - open deck
200 ps/145 tq
200 hp @ 7200 rpm
vtec @ 5500 rpm
redline @ 8200 rpm
rod specs:
civicmatt
10
09-02-2002 07:25 PM
