Primary o2 = male to male on harness?? HELP!?!
Old 08-07-2004, 10:45 AM
mjrage's Avatar
Default Primary o2 = male to male on harness?? HELP!?!
I am trying to figure out where the hell to connect my primary o2.. according to the helms I have the right connector... male looking 4 wire....
On the actual o2... the connector is the same ******* plug.. male 4 wire, same colors... Why is this?
Can I cut both connectors off and splice the wires together??!?
mjrage is offline
Old 08-07-2004, 10:53 AM
pdiggitydogg's Avatar
the one from the car's harness is female - o2's is male
pdiggitydogg is offline
Old 08-07-2004, 10:54 AM
mjrage's Avatar
Default Re: (pdiggitydogg)
on my harness... its male.. Ill snap some pics.
mjrage is offline
Old 08-07-2004, 11:03 AM
mjrage's Avatar
Default Re: (mjrage)
From the Harness:
From the O2:
EDIT:
Im cleaning the IACV aka the Coolant in the bay.
mjrage is offline
Old 08-07-2004, 11:07 AM
CRITTERMATT's Avatar
Which wirng harness are you using. When i performed my swap and installed the wirng from a 99-2000 si i had to buy the O2 sensor for an SI. If you are using an ex harness you need the o2 sensor from an ex. I found this out the hard way. I tries to splice it but ended up with a CEL so i bought an O2 for an SI.
CRITTERMATT is offline
TurboEH2's Avatar
damn. id just cut em and hardwire them together. if i were doing it id solder them and use heat wrap on it. incase of any rubbing that may occur tape em up also.
i like the bungee cord battery tie down.
TurboEH2 is offline
Old 08-07-2004, 11:09 AM
mjrage's Avatar
Default Re: (CRITTERMATT)
Its a b16sirII with an ex harness...in an EK hatch 99
Right now my idle sucks and Im throwing code 41
mjrage is offline
Old 08-07-2004, 11:10 AM
mjrage's Avatar
Default Re: (VTECschmetec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECschmetec &raquo;</TD></TR><TR><TD CLASS="quote">i like the bungee cord battery tie down. </TD></TR></TABLE>
Isnt that JDM yo?
mjrage is offline
Old 08-07-2004, 11:12 AM
mjrage's Avatar
you paid 160 for a new o2 huh? That blows
mjrage is offline
Old 08-07-2004, 11:13 AM
miahmouse's Avatar
Default Re: Primary o2 = male to male on harness?? HELP!?! (mjrage)
hehe, I thought it was just me going crazy or buying the wrong part. I had the same issue when I got a new o2 sensor. just clip the plug off the old o2 and solder onto the new one.
sux though... buying plug and play and not being able to.....
miahmouse is offline
Old 08-07-2004, 11:15 AM
mjrage's Avatar
Default Re: Primary o2 = male to male on harness?? HELP!?! (miahmouse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miahmouse &raquo;</TD></TR><TR><TD CLASS="quote">hehe, I thought it was just me going crazy or buying the wrong part. I had the same issue when I got a new o2 sensor. just clip the plug off the old o2 and solder onto the new one.
sux though... buying plug and play and not being able to.....</TD></TR></TABLE>
What does that mean? What you see is all I have... I bought this car and was not aware of the disconnection and now I am trying to fix it.
mjrage is offline
Old 08-07-2004, 11:20 AM
miahmouse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRITTERMATT &raquo;</TD></TR><TR><TD CLASS="quote">Which wirng harness are you using. When i performed my swap and installed the wirng from a 99-2000 si i had to buy the O2 sensor for an SI. If you are using an ex harness you need the o2 sensor from an ex. I found this out the hard way. I tries to splice it but ended up with a CEL so i bought an O2 for an SI.</TD></TR></TABLE>
I have a 99ex and bought an o2 for a 99ex and it was the same thing.... couldn't find one that would actually work without cutting....
Old 08-07-2004, 11:51 AM
Default Re: (miahmouse)
The o2 sensor from my 2000 EX had the same end as the one on the 99-2000 SI harness I used. Si i thought there must be a difference in the wiring harness but maybe there isn't.
Old 08-07-2004, 01:34 PM
miahmouse's Avatar
did you buy the sensor oem or aftermarket? mine was aftermarket.... maybe they don't realize the 99-00's are different...
Old 08-07-2004, 04:01 PM
5w20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjrage &raquo;</TD></TR><TR><TD CLASS="quote">From the Harness: It doesnt look like the right one because o2s have two green(, one black, and one white wires and all of them are solid colored.
From the O2:Look at the wires.
EDIT:
Im cleaning the IACV aka the Coolant in the bay.</TD></TR></TABLE>
5w20 is offline
Old 08-07-2004, 04:02 PM
5w20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjrage &raquo;</TD></TR><TR><TD CLASS="quote">From the Harness: It doesnt look like the right one because o2s have two green, one black, and one white wires and all of them are solid colored.
From the O2:Look at the wires. See the colors.
EDIT:
5w20 is offline
Old 08-07-2004, 04:14 PM
mjrage's Avatar
Default Re: (5w20)
Its coming out of the o2 sensor...
mjrage is offline
Old 08-07-2004, 04:20 PM
5w20's Avatar
bottom one is correct top one isnt.
5w20 is offline
Old 08-15-2004, 07:19 PM
5w20's Avatar
Default Re: (5w20)
Problem solved?
5w20 is offline
Old 08-15-2004, 10:02 PM
mjrage's Avatar
Default Re: (5w20)
no... getting a new wire harness to fix my problems.
mjrage is offline
Old 08-16-2004, 05:46 AM
just cut the o2's harness, buy a dead o2 from someone here and wire on the connector.
"eeeyyyy" problem solved
Old 08-16-2004, 05:59 AM
RTFM
get another o2 sensor, or jstu the right plug at a junkyard, getting a whole new harness is stupid and a lot more money than gettign the o2 sensor or sensor plug.
v4lu3s is offline
Old 08-16-2004, 10:12 AM
mjrage's Avatar
Default Re: (v4lu3s)
if you saw how mangled everything else was .. you'd get a new harness too.
mjrage is offline
jEGbittner
11-14-2010 12:43 PM
Speedra500
02-17-2008 08:44 AM
pmendoza
03-31-2006 04:21 AM
PrecisionH23a
03-20-2006 10:19 AM
Crimson490
07-30-2003 07:43 AM
Quick Reply: Primary o2 = male to male on harness?? HELP!?!
  • Ask a Question
Question Title:
Description:
