need help to upper the front hood
friend wnat to do the same in his ef sedan like this shot
i need your help what should we need to do?
will water drip into the engine bay or not?
thanks
thanks
Re: need help to upper the front hood (roy civicHBturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roy civicHBturbo »</TD></TR><TR><TD CLASS="quote">friend wnat to do the same in his ef sedan like this shot
will the drip into the engine bay or not?
thanks
you are:
1: the worst searcher I've ever seen
2: the least ressourceful person I've ever seen
3: the most imprecise person I've ever seen
washers and longer bolts my friend
thanks
you are:
most ppl do it if they are boosting to let the heat vent out easier from their engine bay... just use spacers where the hood bolts to the hood brackets on your car. you can use washers, but make sure u don't stack them too high(only 1/2in or so), otherwise your hood will look funny and you'll have a hard time latchin it bcuz of the angle. hope that helps
oh, and water shouldn't get into the bay, unless u have like a 1in gap..or there is crazyass sideways rain.. (powerwasher, ect...)
Re: need help to upper the front hood (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">you are:
i try to search but didnt find it.
any way thanks folks
ok, you put a turbo on but you cant figure out how to put washers in.....anyways
1. unbolt your hood(4bolts)
2. go to loews and get some longer bolts and washers
3. install the new bolts and washers.
Re: need help to upper the front hood (bluemax189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluemax189 »</TD></TR><TR><TD CLASS="quote">ok, you put a turbo on but you cant figure out how to put washers in.....anyways
3. install the new bolts and washers. </TD></TR></TABLE>
thanks
im not turbo yet. im working on it. will finished soon
thanks
Panda-san
02-25-2005 09:48 PM
