~~~~ECU guru's, problem with 4 wire 02 sensor conversion~~~~
Anyone know how to make a P05 ECU work with a 4 wire 02 sensor? I have added a transistor to the Q30 spot and still throwing a code 41. is there anything else that needs to be added?
Thanks in advance.
Thanks in advance.
Re: ~~~~ECU guru's, problem with 4 wire 02 sensor conversion~~~~ (h22dreams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22dreams »</TD></TR><TR><TD CLASS="quote">Anyone? </TD></TR></TABLE>
Re: ~~~~ECU guru's, problem with 4 wire 02 sensor conversion~~~~ (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 »</TD></TR><TR><TD CLASS="quote">Did you use the c144 npn switching transistor?</TD></TR></TABLE>
I ordered some transistors from two different electronic supply stores and neither of them work. I told the electronic stores that this is what I need and they give me something that, "should do it for me". lol
I think I am going to make sure what I am getting is a C144 this next time around.
Do you know where I can get one?
i_drive_a_honda
12-20-2007 02:34 AM
J Rob
12-18-2005 03:24 PM
jeff652
04-13-2004 07:02 PM
