S2000 cluster Pinout
TOO MANY, im the first? i will post the PINOUT for S2000 Cluster!! i try, i try and i can't get the MPH and Temp 2 work!! i can't get MPH pulse right and i can't get the right temp signal from my Eg6.. but this S2000 cluster is Great!! only A few with this cluster in civic and integra!! HERE ARE THE PINOUT
PIN--------COLOR/STRIPE-----FUNCTION
A1---------EMPTY
A2---------EMPTY
A3---------EMPTY
A4---------BLUE/BLACK--------TRUNK OPEN LIGHT
A5---------WHITE/RED---------(CUT) DON'T USE
A6---------LIT BLUE/RED-------(CUT)
A7---------PINK------------------(CUT)
A8---------GREEN----------------DOOR OPEN
A9---------BLACK/WHITE-------(CUT)
A10--------RED/YELLOW--------CUT
A11--------RED/BLUE------------CUT
A12--------BLACK----------------*GROUND*
A13--------EMPTY
A14--------BLACK----------------*GROUND*
A15--------RED/YELLOW---------CUT
A16--------RED-------------------DIMMER
A17--------RED/BLACK----------GAUGE LIGHT
A18--------BLACK/YELLOW------SHIFT LIGHT --S2000 CLUSTER GOT BUILT IN SHIFT LIGHT, U CAN CONNECT 2 AUTOMETER 2 STEP OR 3 STEP..
A19--------YELLOW---------------*POWER*
A20--------EMPTY
A21--------WHITE/RED-----------CUT
A22--------EMPTY
B1----------EMPTY
B2----------BLACK/YELLOW---CHECK ENGINE LIGHT (S2000 GOT 2 OF THIS) CIVIC AND INTEGRA DON'T USE THIS
B3----------BLUE/YELLOW-----CRUSE CONTROL LIGHT
B4----------BLUE/ORANGE-----CUT
B5----------BLUE----------------RPM *BEST PART OF THIS CLUSTER*
B6----------BLUE/BLACK-------CUT
B7----------BLUE/RED-----------SEAT BELT
B8----------WHITE/BLACK-------CUT
B9----------YELLOW/GREEN----TEMP GAUGE
B10---------PINK----------------AIR BAG
B11---------RED/WHITE--------CUT
B12---------BLUE/RED-----------ABS
B13---------BLUE/WHITE--------MPH
B14---------YELLOW/BLUE------EPS
B15---------EMPTY
B16---------GREEN/WHITE-----BRAKE LIGHT (S2000 GOT 2 OF THIS) CIVIC N INTEGRA DON'T USE IT
B17---------WHITE/BLACK------CUT
B18---------GREEN/RED--------BRAKE LIGHT
B19---------BLACK/WHITE-----CUT
B20---------EMPTY
B21---------YELLOW/BLACK-----FUEL GAUGE
B22---------WHITE/BLUE--------BATTERY LIGHT
B23---------EMPTY
B24---------YELLOW/RED-------OIL LIGHT
B25---------GREEN--------------CUT
B26---------GREEN/ORANGE----CHECK ENGINE LIGHT
B27---------YELLOW/BLUE------CUT
B28---------GREEN/RED--------RIGHT TURN SIGNAL
B29---------EMPTY
B30---------GREEN/YELLOW----LEFT TURN SIGAL
A1---------EMPTY
A2---------EMPTY
A3---------EMPTY
A13--------EMPTY
A20--------EMPTY
A22--------EMPTY
B1----------EMPTY
B15---------EMPTY
B20---------EMPTY
B23---------EMPTY
B29---------EMPTY
Re: S2000 cluster Pinout (crx^2yosolo)
what year cluster are you using?
i have a 1st gen cluster and the pinouts are completely different. im looking at the helms right now.
Re: (papito_85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papito_85 »</TD></TR><TR><TD CLASS="quote">post some pix, i'm curious now.</TD></TR></TABLE>
Me too
Me too
Re: ({PBA}Threat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {PBA}Threat »</TD></TR><TR><TD CLASS="quote">I would love to learn how to do this.
As far as everything EXCEPT the Speedo, is everything else just splice and go?</TD></TR></TABLE>
speedo & water temp
somebody - FOR THE LOVE OF GOD - get a TSX or 06+ si speed sensor *slams fist on desk* I betcha speedo would work then!!!!!!
speedo & water temp
Re: (adirondackR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR »</TD></TR><TR><TD CLASS="quote">
speedo & water temp
somebody - FOR THE LOVE OF GOD - get a TSX or 06+ si speed sensor *slams fist on desk* I betcha speedo would work then!!!!!! </TD></TR></TABLE>
the honda gods have listened.... the "05+ rsx/tsx speed sensor works the s2k speedo....only prob is right now is that you need to be K - powered
speedo & water temp
BACK FROM THE DEAD !! !!!!!!
05+ TRANMISSION WITH KPRO or S2k
Parts needed
05-06 tranmission with 05-06 senser
Radio shack - +5V Fixed-Voltage Regulator 7805 ( cost $1.80 )
Maybe add S2k cluster
All you have to Repin the plug at the tranny and add the voltage Regulator!
When done it's going to look like this -->
Step 1: Remove all the pins out of plug on the tranny. Going to have 3 wires, 1. Black , 2. Black/yellow, 3. White/green.
This where you going to add the voltage regulator
Bend the pins like this
With a knife cut a small part of black wire and connect middle pin of voltage Reg. This wire is the ground
On the out side of the voltage Reg. Cut Black/yellow wire and solder the wire on each end. It doesn't matter on which pin u use. - what we doing is Control voltage that is on the black/yellow wire. 02-04 harness n ecu send 12v though this wire! 05-06 needs 5v!
For protection all the wires I use high temp silcone
Last part
The white/green wire is signal. Repin the 3 wires back the plug. In this order
1.Black -Ground
2.white/Green =Signal
3.Black/yellow +5v
All done, it should look like this!
Parts needed
Last part
1.Black -Ground
3.Black/yellow +5v
