d16y7 and d15 vtec (jdm engine) whats best combination for more power?
i have a jdm del sol with d15 vtec engine. i also have a spare d16y7 engine and want to know what is the best combination of the 2 engines. will i use the 1600 bottom end wit vtec top or what is better gearbox ratios to use. any help would be great. tanx
Re: d16y7 and d15 vtec (jdm engine) whats best combination for more power? (fuzzy_mc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuzzy_mc »</TD></TR><TR><TD CLASS="quote"> i have a jdm del sol with d15 vtec engine. i also have a spare d16y7 engine and want to know what is the best combination of the 2 engines. will i use the 1600 bottom end wit vtec top or what is better gearbox ratios to use. any help would be great. tanx
a d15 v-tech...never heard of one of those, but i have heard of a d16 vtech which is the si model for the sol.. the s is just a sohc non v-tech
Re: d16y7 and d15 vtec (IknowYou)
im pretty sure the d15 head should fit on the y7 bottom end, just like my z6 head fits on my y7, you just need the complete head with distributer and the intake manifold, most likely (not 100% sure) need d15 head bolts and run any vtec ecu your just gonna need a obd jumper harness if you go anywhere from obd-II.
search and read BaulyCivic's mini-me writeup and read, read, read! good luck
footwork mastery
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuzzy_mc »</TD></TR><TR><TD CLASS="quote"> i have a jdm del sol...</TD></TR></TABLE>
how is it a jdm del sol??
Re: d16y7 and d15 vtec (PurpleEKHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PurpleEKHatch »</TD></TR><TR><TD CLASS="quote">
how is it a jdm del sol?? </TD></TR></TABLE>
there is a steady supply of 2nd hand ex-jdm cars come to ireland each month, everything from del sol's to bongo buses, the same in australia new zealand & uk,
therfore jdm del sol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IknowYou »</TD></TR><TR><TD CLASS="quote">
a d15 v-tech...never heard of one of those, but i have heard of a d16 vtech which is the si model for the sol.. the s is just a sohc non v-tech</TD></TR></TABLE>
It's spelled...
"V - T - E - C"!
It's spelled...
"V - T - E - C"!
Re: d16y7 and d15 vtec (fuzzy_mc)
you shold just use the D15b that you have in the car. dont swap blocks. put the Y7 head gasket in the D15, that should bump up compression, add about 5 hp. if it is a three layer gasket. im not too sure what comes with the y7. but thats about all you can do. swapping blocks is too much work, probly no gains. tell me what computer (ecu) you have. Maybe i can get you a chip that can help.
footwork mastery
Re: d16y7 and d15 vtec (KISS ME LUCKY CHARMS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KISS ME LUCKY CHARMS »</TD></TR><TR><TD CLASS="quote">
therfore jdm del sol </TD></TR></TABLE>
i didn't even look at location i was expecting it to be in the us somewere
fuzzy_mc
01-26-2006 12:47 PM
fuzzy_mc
01-25-2006 08:44 AM
Slammd Sol
12-27-2003 08:52 AM
